Key FOB question
Old Apr 21, 2014 | 08:41 PM
skratch's Avatar
skratch
Originally Posted by tennispro1
I have had my bike a year now. When do I need to replace FOB or is it just a matter of replacing battery? If I replace battery, do the codes have to be reset? Sorry for newb question, but Im not sure what or when to do this.
Thank you
Ride Safe and Have Fun
your question has a certain air of 'uncertainty' about it. since your question has been answered several times already, i would just add that if you haven't changed the code from what the dealer set, i would do that now. if you aren't familiar with the override procedure, i would also do that now.
get familiar with the process so that if/when you need it, you'll be able to just do the process and be on your way.
Old Apr 21, 2014 | 08:53 PM
Warren9073's Avatar
Warren9073
Beat me by 10 minutes.
Learn to change the code and how to start the bike without the FOB. Someday you will be glad you did.
Old Apr 21, 2014 | 10:05 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
This would be a good idea for everyone...including myself.
Old Apr 22, 2014 | 09:46 AM
Rdgray's Avatar
Rdgray
I've never changed a battery in anything I've owned. 04 Explorer is 10 years old, but all it does is lock and unlock. Last bike was 5 yrs old. I carry the card from the back of the manual.
Old Apr 22, 2014 | 12:10 PM
Warren9073's Avatar
Warren9073
I believe this is correct.....
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Old Apr 22, 2014 | 12:42 PM
Crazy Biker's Avatar
Crazy Biker
Old Apr 22, 2014 | 01:13 PM
HKWildHog's Avatar
HKWildHog
This is great info. I had this problem this past weekend. I just recently bought a 2012 Ultra Limited and it is the first bike I have owned with a security system. I was on a ride about 200 miles from home and stopped at a rest area. When I was ready to depart I could not get my bike to start. I was lucky that I had a spare battery to install, once I did that everything was fine. The odd thing is that I just replaced the battery about two months ago when I bought the bike. Once I get home tonight I am going to get that override code and put it in my wallet. Now that I think about it, this seems like something the dealer should have covered with me on the day I took delivery. Live and learn...
Old Apr 22, 2014 | 01:29 PM
Warren9073's Avatar
Warren9073
On my 2012 Fatboy if the FOB is not present or the battery is dead it automatically asks for the code when I turn on the ignition.
Old Apr 22, 2014 | 01:41 PM
CRF's Avatar
CRF
do you need to know the existing overide code to change it?... bought my bike used and don't know the existing code.
Old Apr 22, 2014 | 02:00 PM
Warren9073's Avatar
Warren9073
No you do not need to know the existing code. As long as your FOB is present and working when you go into the setup you will see the existing code. At that point you can keep it or change it.
