Primary chain tensioner concern
Old May 3, 2014 | 06:46 PM
deadman77's Avatar
deadman77
Originally Posted by Uncle Chester
Those are the only ones I have heard of any issues with. The self adjusters can tighten up the chain but have no way to back themselves off. You end up cruising around with the chain way to tight and it can cause all kinds of issues. That said there are tons of high milage bikes out there that have never had issues with the auto adjusters. Not sure if it's luck of he draw or if riding style has anything to do with them over tightening.
This is exactly why I removed mine. It was the HD accessory. Seemed like a good idea but after inspecting the chain due to a noise it was tighter than you can imagine. They ratchet up but cant relieve the tension. That has to be done manually.
Old May 3, 2014 | 08:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the overtightening of the chain, the Haydens allow for chain flex on loading and unloading conditions, Accel and decel. I've got Hayden adjusters on all 3 bikes, really like them.
Old May 3, 2014 | 10:18 PM
3408pete's Avatar
3408pete
Well I have researched this site and others on the subject and end up walking away with the same thoughts that none of the above have a strong enough following to sell me on whats right. Baker has always been a good product but like what was mentioned there is a side affect of using them. My dealer refuses to use the hayden on anything that has any mods on the engine.
Old May 3, 2014 | 10:39 PM
Fishrrman's Avatar
Fishrrman
Originally Posted by PaiN
Both the primary and compensator adjusters are antiquated engine technology that have no business in motors as powerful as the 96 and 103 are. Too much motor for too old a technology, this is the reason of over-wear at low miles and premature failure.
Just wonderin', but what better arrangement could they put in there?
Gears? Belts?
How do Victory and Indian handle the primary side of things?
Old May 3, 2014 | 11:08 PM
GNrider's Avatar
GNrider
If you look at the design of the Hayden, it just makes sense. I've had them on both of my bikes without a problem. I just installed on a friends 2 weeks ago and he is happy as well. Really worth looking at.
Old May 3, 2014 | 11:35 PM
Twistnride's Avatar
Twistnride
35,000 on a stage ll 103. Forget all this internet horsecrap,and ride the damn thing. What problems?
Old May 4, 2014 | 03:36 AM
superwoody2's Avatar
superwoody2
Been putting Haydens on all my bikes over the years and am very satisfied, BUT, I don't beat on my bikers either.
Old May 4, 2014 | 04:37 AM
Stiggy's Avatar
Stiggy
141,000 miles on a '00 FLTRSEI equipped with a Hayden and never one primary issue thus far. Original clutch and chain and the only refresher was a new spring cap on the compensator just for good measure at 120,000.
The bike pits out 85 HP and 95 FT/LBS TQ, about the same as a new 110" Stage I today.
The primary problems started with the 96" motor mated to the 6 speed transmission, first in the '06 Dyna (guinea pig,) and the all big twins in '07 and later when they all got that combination.
Its a design flaw IMO, not a power issue.
Old May 4, 2014 | 05:56 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Disreguard this post....Different year, different compensator...sorry
Old May 4, 2014 | 07:58 AM
hardheaded's Avatar
hardheaded
my 12 streetglide tensioner was to tight and was wearing uneven. seen problems with the hayden tensioner ,decided to go with the baker attitude. so far it's the best thing i've done so far. less noise and alittle easier shifting. nothing going to stop that clunk going into first unless you pull the clutch in for 20 to 25 seconds before dropping into gear. that seems to work the best. with the manual adjuster in there i don't worry about it running to tight. removing the compensator is no big deal, takes 10 min. easier on bearing too, don't know why harley ever got away from the manual adjuster in the first place.
