3/4 with full face mask. Depending upon how low I pull the mask will measure how much wind noise I have. All the way down and there is some noise, but tolerable.
I have used a few different types and so far the foam plugs seem to work best. The plugs I use at concerts stick out of my ear a bit and when I put my full face helmet on they can be pulled out. If the foam plugs dont fit as well I have aslo found that cutting off some of the end (the end that goes in the ear) makes them fit better.
I also use a 3/4 helmet, and in cool weather have a bubble shield on it. If I am on the freeway or going to be riding more than 5 minutes I try to put in some foam ear plugs. The silicone ones are good too, but I loose them too quickly.
I've used the LEIGHT foam ear plugs from Dollar General. They are safety orange color and block out 33db. $2.00 - $2.50 for 5 pr. I use about two packs a riding season. Work great for me.
Next bike show look for fit-ear. They inject the material into your ear canal and make custom ear plugs at a very reasonable price. BTW, even if you ride with a full face or 3/4, if you don't wear plugs eventually you will damage your ears.
I use the Howard Leigh orange foam tapered plugs when riding without my windshield. There are several styles of foam plugs. If your not going for a custom fit find the shape that works best for you.
Those orange ones from Howard Leigh i swhat i use, they are sufficient and i can still here ambient noise.
For those interested in noise canceling ear buds.....this is a good article. I wear. Half helmet and earbuds with my iPod on medium volume. Also putting on a windshield helps considerably.
i forgot to mention that i just had an appt with an audiologist. she said that these fit so well, that she would not recommend spending the money on getting custom ones made. if i insisted, she would, but recommended against.
i like these, and they aren't too expensive. i like that you can pop the center cap open when you're at low speed or stops and then shut it again to block the louder, more damaging noises.
+1 on the Surefires. I started wearing them last year and have been extremely satisfied. I can hear the engine, I can hear ambient noise, but the wind noise is gone. And they're quick and easy for me to put in.
