tonights project....and a question
Old Jul 23, 2014 | 07:43 PM
tehan2's Avatar
tehan2
Default tonights project....and a question
Got home from work today and there was a package at the door. My kids got me a Labroila Jockey shift for fathers day (ordered 6/10 arrived today)
So I went to work and skipped dinner. Here's a crappy picture
I've had a jockey shift before for a short time.
Here's my question
The clutch comes on like a freight train. I've tried to adjust cable and clutch itself with no change.
It almost wants to come up into a wheelie leaving in first. Any Ideas on what I'm missing?
oh and of course 2-5th are all fine
Old Jul 23, 2014 | 07:54 PM
Harley Rookie's Avatar
Harley Rookie
6th Gear
I don't have any advice on the issue, but would like to know what your thoughts on the kit are. I have been wanting to put jockey shift on mine and it doesn't seem like there are many choices for a kit.
Old Jul 23, 2014 | 08:18 PM
tehan2's Avatar
tehan2
he's pricey... but it 100% complete with everything you need, with decent directions. The parts themself are beautifully/quality built.
It took me 2.75 hours, but that included pulling exhaust and grinding down a pair of needle nose pliers because I couldn't find my snap ring pliers and talking to my mother who called while I was laying on the garage floor.
If I have 1 complaint about it as a DIY it would be a Harley issue. some parts using metric fasteners and some SAE and a few of them that they must have used the world's strongest man to tighten. I actually snapped an allen wrench trying to loosen a bolt
I should also mention that when you first open the box, there was a moment where I said...this is what I waited almost 6 weeks for? but as you see how easily everything goes together and the quality of his machining you see why the delay,
Old Jul 23, 2014 | 08:40 PM
pococj's Avatar
pococj
It may be nothing more than a matter of acquiring the "feel" for your particular set-up. I had one on my Nightster and it was a lot touchier than the one I have on my '87 Sloptail. They are also a little touchy if the clutch plates get even a bit sticky. One thing that can help is to make the lever longer; this makes your foot travel a longer distance to move the cable/clutch plates the same distance. But it isn't an easy fix, depending on how the clutch pedal/lever is fastened to the mount, whether you can fab and weld, etc.
Old Jul 23, 2014 | 08:50 PM
tehan2's Avatar
tehan2
I didn't even think of the lever....I put the HD lever on and put the Labroila lever on the shelf. They are different lengths. I 'm going to try that tomorrow (But the HD lever is a little longer. I would think that helps , but I'll see)
Old Jul 23, 2014 | 08:57 PM
tehan2's Avatar
tehan2
I gotta do something about my shifter ball too.. Tightened up the numbers face the wrong way
Old Jul 23, 2014 | 09:20 PM
back again's Avatar
back again
Get a thin nut from the hardware store to lock the ball. There should be enough thread for a locknut.
Old Jul 24, 2014 | 04:49 PM
tehan2's Avatar
tehan2
just as an update. It was an install error. I adjusted the lever so that the cable bottomed out on the floorboad instead of when the clutch disengages .
So as as I was traveling 5" or so with the lever, it felt like it was hitting hard.
Now adjusted correctly, rides like I remember. I did 30 miles right after work, going to head out when rush hour is over to get more "practice"
Old Jul 24, 2014 | 07:33 PM
Bocefus's Avatar
Bocefus
Sweet.
scottt
2014-2024 Touring Models
30
Sep 22, 2018 07:05 PM
Dutch101st
Jul 26, 2014 02:24 PM
WhiteNoise
May 21, 2014 05:40 PM
SANTA DEUCE
Dec 30, 2012 07:51 PM
nightie
Aug 24, 2012 09:51 AM
