Blow by
Old Aug 24, 2014 | 07:47 PM
FNGonaRK's Avatar
FNGonaRK
Back the oil level down about 1/4 of a qrt. That will probably solve the problem completely.
Old Aug 24, 2014 | 08:29 PM
NightHunter's Avatar
NightHunter
[quote]b
Old Aug 24, 2014 | 08:55 PM
the4thgearkid's Avatar
the4thgearkid
Originally Posted by Iceman24
Blow-by can also be caused when the OL chokes on the jizzz...
That was funny
Old Aug 25, 2014 | 07:07 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by NightHunter
...and for you Pine Tree- YUP !! looks like i have my answer now doesn't it-
Cheers!
What are you, 6 years old? That's got to be one of your most immature replies yet.
Old Aug 25, 2014 | 07:46 AM
Throttle_Jockey's Avatar
Throttle_Jockey
Not to sound like a dick, but if it was built by the best in the business why is the breather still going to the air cleaner? (Of course assuming this is what your talking about).
Oil mist in the air/fuel helps power in no way shape or form. Running the breather hose it to a crank vent or even out into the apmtosphere is better then putting back through the carb.
Old Aug 26, 2014 | 04:28 PM
Bingee's Avatar
Bingee
The crankcase has to be vented to dissipate a number of gasses that accumulate there. Some would shorten engine life if not removed. So the vent has to go somewhere. If it all went to the atmosphere the roads would eventually have a black coating due to the oil mist making them slippery and risky for motorcycles to be on. In addition there are environmental issues. So presently the breather system is all that's practical.
Old Aug 26, 2014 | 04:40 PM
YeOldeStonecat's Avatar
YeOldeStonecat
In addition to not topping off the oil as high next time.....also check those 2x rubber hoses that route it to behind the air cleaner. Those hoses often crack, and leak. I replaced them with high temp silicon hoses from NAPA...about 3 bucks...I cut 2x lengths from it about 1.5" longer than originally was. (this was on my prior Harley...'06 FXDBI).
Old Aug 26, 2014 | 04:46 PM
Bill Day's Avatar
Bill Day
Didnt get a chance to read all the replies but I'll give a quick experience my buddy had:
His 01 ultra classic police parade is a 95" he had some cams put in and didnt like the way it ran, Couldnt keep up with my stock 03 RK Classic so he sent it back to ahve them changed back.
Got it back and it started doing to blow by. Seems that when you get a cam kit there's and o-ring for the oil pump(that wasnt with the cam kit the guys installed) that typical come with most cam kits.
Anyway the guys that did the work figured it out and replaced the oil pump o-ring and it's completely stopped
Kinda short on details because it wasnt my bike but I hope it helps.
Old Aug 26, 2014 | 04:48 PM
soft 02's Avatar
soft 02
Originally Posted by Bingee
What some think is blowby is actually a pressure increase in the case caused by rapidly descending pistons in the cylinders. So don't go doing a top end unless you have proof the rings are shot.
Yup. Modifications to the breathers can help. The problem can be as simple as a bad umbrella.
Old Aug 26, 2014 | 06:30 PM
OLD 96's Avatar
OLD 96
There ya go right there. Had the same thing happen to my 07 Ultra. My indie told me umbrellas will dry out and go bad. Causing air cleaner to "leak oil". He recommended trying not running the oil level all the way full.
