Impact Driver Recommended?
Old Sep 21, 2014 | 04:13 PM
Spartanden's Avatar
Spartanden
To be clear, I think the OP was talking about the hand held impact driver...the kind you hit with a hammer. Not an impact wrench. Haven't found much use for an impact wrench. Yet!
Old Oct 6, 2014 | 03:33 AM
FASTFXD's Avatar
FASTFXD
Always thought of a hand impact driver as a "must have" as back in the day, they were. Still have one I use to use regularly. Now, not so much but like someone else said - when you need it, it's there.
FWIW, they can be quite useful and better than an air tool because you can be very gentle with it, applying strikes just light enough to break a bolt free. Learn how to use one and you'll be amazed at how easily you can remove a stubborn bolt w/o buggering the head.
Old Oct 16, 2014 | 08:00 AM
black01's Avatar
black01
I have one that I use on my bike and truck a lot. But its a impact driver. its a Milwaukee 12v lith. I use it to remove bolts and nuts, but not put them back in/on.
Old Oct 16, 2014 | 09:43 AM
Uncle Larry's Avatar
Uncle Larry
Big difference between an Impact Driver ( one that is used with a hammer ) and an Impact Gun/Driver that is electrically powered. Yes, a hand operated Impact Driver ( that you strike with a hammer ) is a valuable asset to any tool box. I'll bet a number of old riders here were weened on some the Jap scooters. An Impact Driver was a NECESSITY when working on them.
Old Oct 16, 2014 | 09:56 AM
Duracell's Avatar
Duracell
Impact Wrench
Impact Driver
Old Oct 16, 2014 | 10:05 AM
Uncle Larry
Originally Posted by Duracell
Impact Wrench
Impact Driver
Yep ... This! Thank you sir.
Old Oct 16, 2014 | 11:47 AM
Strahley's Avatar
Strahley
I recently had my bike down to the frame and didn't need an impact for any of it. The swingarm pivot nut was a little rough at first, but a 36" pipe as leverage made short work of that. Absolutely shouldn't need one for a derby cover
Old Oct 16, 2014 | 12:22 PM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by Spartanden
I've had an impact driver for over 40 years. Hardly ever used, but when I need it, it's there. Craftsman, Mac, Snapon are all good choices. You may never use on derby covers ( I did on a Sporty) but you may be surprised where you might need it. I would seriously add to your kit....maybe not priority, but a need in my opinion.
Old Oct 16, 2014 | 12:43 PM
Duracell's Avatar
Duracell
I'm glad you got the swingarm pivot nut off with out damage but it's been my experience in the past that anything that requires that much "cheater" bar often shears off the stud before it breaks the nut free. The hammering affect of an impact wrench often breaks the bond on stubborn fasteners with out breaking or stripping them.
As far as the derby cover, the impact driver is absolutely required for over tightened torx fasteners and is sometimes the difference between removing them or stripping the heads off.
Just my opinion
Old Oct 17, 2014 | 02:20 AM
Piloto's Avatar
Piloto
Amen. Worked in a small Honda shop back in the day. It was a must have, not a nice to have.
