kickstand dragging
Old Apr 19, 2007 | 11:45 PM
skinhead's Avatar
skinhead
Default kickstand dragging
I have a 95 Sporty and my kickstand is drooping down low , i changed the spring but it still droops ,any idea
Old Apr 20, 2007 | 01:56 PM
fxstcguy98's Avatar
fxstcguy98
Default RE: kickstand dragging
I'm not real sure if a 95 Sporty is the same as mine, but pretty sure it is. There is a cam shaped piece in there that holds the kickstand up and down, could be that it is worn badly, also look at the tab on the kickstand and see if that is bent or worn out. Replace which ever is the culprit.
Old Apr 21, 2007 | 05:56 PM
skinhead's Avatar
skinhead
thanks for the advice , i will check it and let you know
Old Apr 28, 2007 | 06:15 PM
m.breen's Avatar
m.breen
I had the same problem on my '93 I tried 2 springs and no luck, changed the pin and voila problem solved. I almost bought a new kickstand for $250 out of frustration after the stealer sold me 2 bushings. (mine does not have bushings).I rode 2 seasons with my stand scraping, and people stopping me to say my kickstand was not up.
Sliver1
Mar 31, 2014 05:29 AM
DiggerG
Jun 26, 2012 04:47 PM
faber
May 8, 2011 12:06 PM
flyrodtheropy
Aug 7, 2008 11:15 PM
flyrodtheropy
May 26, 2008 07:15 AM
