Barnett Clutch Cable
Old Mar 5, 2015 | 11:22 AM
UncleBill's Avatar
UncleBill
Default Barnett Clutch Cable
2005 FLHTCUI
I am replacing 8" bars with 10" bars.
I want to replace the clutch cable with a new S. Steel Barnett 4" over stock length cable.
Confusing trying to find the correct part number..
Any help would be greatly appreciated.
P.S. I am replacing the top riser clamp with a one piece.
Also, would like any input on replacing riser bushings with urethane ?
Thank You !!
Old Mar 5, 2015 | 04:03 PM
dfwhockey17's Avatar
dfwhockey17
I would love to help.
According to the Barnett cable section in the 2015 Drag book:
Stock cable: 62.25" center adjuster
Part #: 0652-0510 is 65.25" (+3) center adjuster, Platinum finish
Part #: 0652-0513 is 68.25" (+6) center adjuster, Stainless Steel finish
*They are not offering anything in +4" in the Drag book
*They are not offering a +3" in Stainless Steel finish, Platinum only...
At our shop we always use Ness Poly H/B bushings, part number for your bike is: 0604-0008. You don't need to use the Ness brand but make sure you get a good set of poly bushings as this will eliminate all the slop that will be present...
Old Mar 5, 2015 | 05:39 PM
RKGDCG03's Avatar
RKGDCG03
Veteran: Coast Guard
Call Barnett direct, 805-642-9435, and tell them what you want and they will make to your specifications. That is what I am doing for my RK.
Old Mar 6, 2015 | 12:36 PM
UncleBill's Avatar
UncleBill
Thanks guys..
Very helpful
Graggy
General Topics/Tech Tips
Jun 15, 2019 07:23 AM
gnalen
Jul 31, 2017 01:31 PM
cripple
Nov 17, 2012 05:44 AM
GregX999
May 2, 2012 11:56 AM
misfitchris
Nov 8, 2011 01:29 PM
