Oil leaks from push rods tubes
Old Mar 28, 2015 | 12:19 PM
Dr Rock's Avatar
Dr Rock
Stage I
Default Oil leaks from push rods tubes
Hi
Since the rebuild of my 1976 shovel, I ma getting oils leaks. Fixed front cylinder rocker, now having problems with excessive oil from front cylinder push rod tubes. Has an S&S oil pump so was wondering if I could reduce pressure some how as maybe over pressurising system. I put breather hole in oil tank cap and there is definitely pressure coming through the hole. Any input much appreciated.
Thanks
Chris
strych9
Engine Mechanical Topics
Aug 1, 2020 03:10 PM
streetglide99
Shovelhead
16
Oct 23, 2014 03:06 PM
gilb
Panhead
32
Dec 4, 2010 09:16 PM
dwn1383
Panhead
14
Mar 24, 2008 03:03 PM
Joekansas
Classic
Aug 8, 2005 08:55 PM
