Squeeking Noise
Old Oct 18, 2015 | 05:58 PM
gregm's Avatar
gregm
Default squeaking
Check the rubber muffler mounts. Mine drove me nuts until I inserted a piece of plastic milk container between the rubber mount and the bracket.
Old Oct 18, 2015 | 07:16 PM
89FLHTC's Avatar
89FLHTC
I was hearing a chirp when I snapped off of the throttle while doing 50-60 mph. After doling some research, I found that a lot of the time, a loose belt would cause the chirp so, while checking the tension on mine this morning, I found that I could deflect my belt from the bottom of the winder to the top with very little pressure. I guess thats about an inch of deflection. So, I consult the manual which gives a spec of 5/16"-3/8" deflection, cold, with 10 lbs pressure. Not having the gauge, I tooka chance and adjusted it by feel to 3/8". When I test drove it, it seemed to shift better and smoother. Maybe my imagination? Anyway, after riding for about 10 miles, I rechecked the deflection of the best and it was around 1/4". So, now I am thin king its too tight. What say ye ?
Old Oct 31, 2015 | 09:07 AM
theojkett's Avatar
theojkett
Default I may have the solution
Originally Posted by GaJayhawk
I've got a 2000 Road King Classic. I can often hear a "chirp" when I ride along side a Jersey Barrier on the highway. I suspect the chirp is always there, but I only hear it when there is something to bounce the sound back at me. The bike has had Rinehart True Duals on it for 10 years, and I thought the sound was coming from the rubber rear mounting bushings, but lubing those up didn't help. So I tried Teflon spray on the drive belt and rear pulley. That fixed it. However, it wears off after a few hundred miles and the squeak returns. Knowing what it is, I just live with it.
I have a 2003 Heritage and I had this squeak. Took it to the dealer and they had the bike for a few days and gave me the full gamut of things it could be. If I left it up to them I would have spent nearly $3000 in un-necessary repairs. I did let them replace the rear bearing, $300 but that wasn't the issue either.
Harley puts these plastic shrouds under the bike that are connected to the rear fender and are the same shape of the rear fender... sort of an extension of the fender and it bolts to the frame right next to the drive belt underneath. I was just about to lube up the belt with soap so the squeak would stop when I noticed that this fender shroud was worn away by the belt. I had the bike on the lift so I spun the wheel slowly and wouldn't you know it, the belt was ever so slightly hitting the shroud and making a noise. So I got my razor knife and trimmed the shroud 2" long by 1/8".
I would get this noise after about 8 miles of driving, after the engine was nice and hot. Hot enough that it would warp a plastic part out of shape. Since I did that little trim I haven't heard that noise.
Research will save you hundreds of dollars.
Ride Safer.
Ted
Motorcycle Men Podcast
www.motorcyclemen.us
Old Nov 1, 2015 | 04:29 PM
89FLHTC's Avatar
89FLHTC
I had that exact noise and it was a loose drive belt. Drove me nuts till I figured it out.
Allen Tate
Oct 20, 2016 07:28 AM
beaucipher
Aug 2, 2014 12:07 PM
hdbiker123
Apr 2, 2014 07:49 AM
Captain Smooth
May 19, 2012 10:33 PM
Bluehighways
Jul 22, 2010 08:30 PM
