selecting the right cams
Let's say that is your choice… then the 'build' needs to work around that cam. You can send your heads out and have them ported; about $200 each and they need to know what cam you have and what compression you want. If you go over 9.5-1 you will need to always add octane booster when you fuel, you could make a bit more power with a higher compression ratio, but I don't think that is what you want. Just tell whoever does your heads you want to run pump gas.
Now you have re-worked heads/a good torque cam.. change your pushrods over to adjustable, and put in new lifters. You already have hydraulic cam chain tensioners, but have them checked for wear. While in the cam chest you can also replace your 'lefty' bearing to a roller bearing (always a good idea when making more power).
But before all of this, you have to decide if you want to go to a 103".. if so, then everything else needs to be built with that in mind.
And again; to make all this 'work' like you want, a fuel tuner is a necessity.
(the 103" will give you more power across the board, but of course, more $)
.. a 96" you say.. Okay, then. Much simpler and cheaper. So now what.?
.. a HD 203 cam, adjustable pushrods, new lifters, re-worked heads (and while in the cam chest; lefty bearing, check tensioners, new cam chain (optional, but just a few more bucks)
.. one more thing to mention; when the heads are being done, you need to ask what size gasket you will need for the compression ratio you want: 0.03, 0.04, 0.045. Each gasket size will equal a different CR
.. then; do your mechanic magic …… and when done, take the bike and the fuel mapping product you and your tuner have decided on, get it on the dyno and then a few bucks later… you have a new engine build.
**Now, I am no know-it-all, so please, forum members, add/correct my 'how-to' to get this biker a build he wants.
(remember; planning your build is half the fun..! at least for me it was..
It's an '07, decent heads already. Maybe go with a .030 MLS Head gasket set.
Make sure cam chain tensioners are in good shape.
Hardest part of this whole job is getting the intake all lined up and snugged down and putting the exhaust back on.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Said the short shots dont have enough back pressure. I pipes are next.
