Motorcycle Lift
Old Jul 11, 2015 | 10:19 PM
dirtfarmer's Avatar
dirtfarmer
I've got the HF lift and love it. It took a little while to get the positioning right. I have to have a short piece of 2x4 on the front arm to lift my bike up level. I did switch out the bolts for grade 8 pieces just for my own peace off mind and used washers to take up some of the slack in it. I was a little leery of it the first couple of times I used it but after seeing how solid my bike sits on it, I don't worry about it now. I really like being able to sit on a stool to work on the bike.
Old Jul 13, 2015 | 12:42 AM
Bafulgaro's Avatar
Bafulgaro
I'm also curious, what is the safest way to put your bike on and off the lift? I just purchased a lift and concerned about the the tip factor as you load and unload your bike by yourself
Old Jul 13, 2015 | 05:45 AM
stellarpod's Avatar
stellarpod
I bought the 12" side extensions for my Handy Lift, which gives you room to put your feet down. Problem solved. Also gives lots of room for tools and parts while you're working on the bike.
Steve
Old Jul 14, 2015 | 11:23 AM
fatusboyus's Avatar
fatusboyus
Originally Posted by Hey Man
Check with your local dealership. A buddy of mine just bought a bought one from his local for $300.oo. Supposedly the dealerships replace their lifts every year or two and sell of the used ones.
I don't have the available floor space for a full size table lift so I bought a like new Kendon Lift off craigslist for $350. It's pneumatic over hydraulic, I use it when I need it and the rest of the time it spends standing up against the wall. I'm really pleased with it.
I have this same kendon lift and love it.....very space efficient when not in use, I just wish you could buy (as an accessory) an adapter to make it work with your air compressor and switch it to a hydraulic lift
Old Jul 14, 2015 | 11:47 AM
dfwhockey17's Avatar
dfwhockey17
Originally Posted by just plain john
How do you get it on/off there without being able to put your feet on the ground?
You push the bike on and off the lift. If you are not strong enough to do so you can start the bike put it in gear and walk it using a bit of clutch to help drive it up on the lift...
Old Jul 16, 2015 | 08:50 AM
t100rc's Avatar
t100rc
^this.
When I was working in the motorcycle shop, we only RODE our own bikes onto the lifts, and even that was rare. You just push them up ... It was only the biggest and heaviest that got the clutch assistance. With large and/or awkward bikes, we would often help each other strap them and sometimes either give a little extra push from the rear or just be there to 'spot' each other. Mostly, though, you handled everything that went on to or off of your own lift ...
Old Jul 16, 2015 | 03:01 PM
stellarpod's Avatar
stellarpod
Originally Posted by t100rc
^this.
I believe this is sound advice. However, if the side extensions are on the lift there's really not much risk, as there's ample room to plant your feet.
Steve
Old Jul 21, 2015 | 08:35 PM
Fireguy88's Avatar
Fireguy88
I'm considering the weaver lift. For those who have it. Is it hard to move it around in the garage/reposition it? I'd like to be able to move it further to the side of the garage in the winter months so my GF can park her car in the garage.
Thank-you
Old Jul 22, 2015 | 05:53 PM
dfwhockey17
^The Weaver lift is not hard to move at all when it is down. A light push with your foot will move it side to side very easily, same with forward and back...
Old Jul 28, 2015 | 07:30 PM
Hey Man's Avatar
Hey Man
I push it up, with help.
