Throttle Cables
Old Feb 3, 2016 | 05:16 PM
bigpappa160's Avatar
bigpappa160
Default Throttle Cables
I have a 91 Ultra Glide. How can anyone tell if their throttle cables has stretched? Can you adjust throttle cables?
Old Feb 3, 2016 | 05:26 PM
bigpappa160
If I replace them, what is a good brand and the length I need. I've looked for some and some say 34" some say 36"
Old Feb 3, 2016 | 08:49 PM
SiggerTX's Avatar
SiggerTX
They are indeed adjustable, the adjusters should be about 3" from the throttle housing.
Old Feb 4, 2016 | 10:49 AM
chromelens's Avatar
chromelens
Drag Specialties makes a fine replacement cable. If you want to upgrade Magnum and Barnett also make an excellent cable. Throttle cable is 38" long-70 degree elbow-5"cable travel. Idle cable is 38" long-70 degree elbow-4 3/4" cable. If your cables are frayed, tough to pull, or the outside cover is cracking or broken you should replace them. Check a service manual on proper adjustment and replacement.
hell hound
Shovelhead
Apr 5, 2018 10:15 AM
twistedcherokee
Mar 25, 2016 07:39 AM
workingdan
Carburetor Related
Apr 21, 2015 05:03 PM
msamarah86
Jun 22, 2011 07:34 AM
98sportyil
Jul 30, 2008 08:18 AM
