Issues with my 2006 Classic
Old May 1, 2016 | 08:04 PM
labejohw's Avatar
labejohw
Stage I
Default Issues with my 2006 Classic
Hey, this is my first Harley. I bought a 2006 Electric gluide Classic. I have taken it to Harley because after riding for a while it will not idle at a stop. They couldn't figure it out . I think it is the TCP, but could use any advice. Thanks
Old May 2, 2016 | 11:59 AM
enodrano's Avatar
enodrano
Dirty or improperly gapped spark plugs.
Dirty air filter.
Old Fuel.
Bad fuel pump.
Clogged fuel lines and/or filters.
Improper or corrupted tune/map.
Set the idle rpms (Carburetor only)
Just a handful but they are cheap and easy to fix or replace.
Old May 2, 2016 | 12:04 PM
nevil's Avatar
nevil
To the above you can look at a dirty IAC. Easy enough to clean.
Not sure what the TCP is, but you may be thinking of the throttle position sensor.
It would help to get more info, like exactly what the dealer did. And what kind of mods or tuner that the bike has, mileage, etc.
Old May 5, 2016 | 08:59 AM
Technician Dave's Avatar
Technician Dave
Stage IV
The 2006 models were famous for the throttle stop screw loosening on its own and backing out. If you're facing the air cleaner, look on the right lower side where the throttle cables are. There is a round piece of metal called the bell crank. Look as you open and close the throttle (engine off of course.) You will see where the bell crank comes to rest, there is a piece of metal and a screw (throttle stop screw.) If the bell crank is NOT touching it with the throttle at 0%, it is backed off and out of adjustment. The screw is a special 5 sided TORX. If you find the screw loose, I would take it back to Harley because they will need the Harley computer to reset the TPS properly.
Burden1981
General Topics/Tech Tips
Aug 23, 2018 06:39 PM
tkenney2nd@yahoo.com
Oct 26, 2016 03:32 PM
Jimbo63
Sep 2, 2010 10:10 PM
06EGlide
Jul 15, 2009 06:17 PM
19rooster58
Apr 3, 2009 02:44 PM
