Help w/air compressor!
Old Jun 6, 2016 | 08:38 PM
ckamin's Avatar
ckamin
Default Help w/air compressor!
Howdy! I have a Craftsman 33 galon stand-up compressor that I use for my Kendon lift. The compressor itself seems fine and it pumps up to 150psi at the air pressure switch as always... However, the max pressure I can get at the adjacent regulator is about 80psi even with the **** turned to max pressure. Could the regulator be the culprit or a blockage between the switch and the regulator be the issue? It wasn't always like this...
Thanks!!
Old Jun 7, 2016 | 12:57 PM
Brian Kelley's Avatar
Brian Kelley
Couple of things. Since it's Craftsman, you could try contacting Sears to see if their "lifetime" tools warranty covers your unit. I tend to doubt so with motors/electrical, but worth asking.
Maybe the gauge dial indicator is faulty? Try knocking it? Try driving a large air impact wrench or other tool. Does it feel like 80psi or more like 120-150?
If it is actually weakened output, I'm guessing there must be internal bushings & seals at the output that could have eroded, and is causing leakage (?). Maybe Sears repair can do a diagnostic? No doubt a pita!
07ntrain
Jul 15, 2015 04:56 PM
Lenny 99
Electrical/Lighting/Alarm
May 8, 2014 04:58 AM
papa_freeman
Mar 25, 2009 07:14 PM
07 desert sled
Sep 11, 2007 09:12 AM
Wolf
General Topics/Tech Tips
May 15, 2005 12:12 AM
