Cam question
Old Sep 28, 2016 | 09:37 PM
PIGME3256's Avatar
PIGME3256
3rd Gear
Default Cam question
I currently have the SE-211 cam in my FLHTCUI and doing a Dave Mackie Engineering 95" build.
If I am reading everything on the charts the 211 fits in between his 510 and 590? I am not looking to set the Senior National Bagger Speed Championship record. Just a good steady pull...
What say you fellow motor guru's?
Am I reading the charts correctly?
Thanks
Old Sep 28, 2016 | 11:08 PM
qtrracer's Avatar
qtrracer
I had DME 575's in a 103" , if I was you I'd go with his 590's for your application. You will probably pick up some tq over the 211's. Plus my guess is his head work will be matched better with his cams that he knows what they like. Definitely need to check piston to valve clearance at tdc though. Dave is a pretty good guy.
Old Sep 30, 2016 | 05:24 AM
grbrown's Avatar
grbrown
Call DME and talk through what you want of your bike, then use the cams he recommends. That will get you the best performsnce from your investment and his hard work.
Old Oct 5, 2016 | 08:30 PM
JMC22's Avatar
JMC22
I'd recommend the S&S 570
Suasponte01
Engine Mechanical Topics
Apr 4, 2017 02:00 PM
ChangedBagger
13
Mar 15, 2015 08:01 PM
Chad263
Jan 2, 2011 09:00 AM
Sash302
May 30, 2009 08:32 PM
SeaHag
Exhaust System Topics
Aug 14, 2008 01:51 AM
