Trouble code 2206b
Old Dec 21, 2016 | 08:59 PM
Kmstradtman's Avatar
Kmstradtman
Default Trouble code 2206b
Anyone had 2206b "run stop switch input open/shorted high" pop up as a trouble code. I have a 14 fxdl that I'm having this issue with. Engine cranks but won't start. Changed bars out about 6 months ago. Haven't found any messed up wires so far. Any way to bypass this. And could a bad battery play any part in this error code?
Old Dec 25, 2016 | 01:19 PM
Quiet Thunder's Avatar
Quiet Thunder
When you removed and replaced the right grip assembly, did you re route the cables back into the grove in the handle bar, if there was one? And did ypu make sure the wire bundle was correctly re-routed out of the assembly?
Old Dec 25, 2016 | 04:37 PM
Kmstradtman
Thanks for the reply. Turned out my FP3 malfunctioned when it updated the firmware. Took the map back to stock and codes disappeared and the bike was back to normal. Then I was able to update my map. Glad there wasn't actually a short somewhere.
jjohnsonkc
Aug 11, 2018 09:46 AM
mja52403
Apr 30, 2017 12:31 AM
Bogie_71
Sep 25, 2016 12:12 PM
jmcollison
Mar 4, 2015 07:35 PM
