Derby cover replacement tips
Old Jan 9, 2017 | 11:02 AM
roussfam's Avatar
roussfam
Yes loctite, no loctite....may the best man win. ...
Old Jan 9, 2017 | 11:37 AM
crazytown's Avatar
crazytown
That made me snort laugh. My excuse is that I'm on cold medicine today.
Old Jan 9, 2017 | 04:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
So...OP, are you going to tell us what you are working on?
Old Jan 9, 2017 | 04:36 PM
NCBANDIT's Avatar
NCBANDIT
Yes, it is a 2016 Slim S.
Old Jan 11, 2017 | 10:40 AM
Max Headflow's Avatar
Max Headflow
Blue LT is fine I find the screws less sticky using some of the blue.. I only Tq the screws to about 60 in lb..The screws on later bikes are T27 .. Don't use a T25.. If the screw seems to need excessive force. You might need to tap on the screw a little.. If you are using a socket with remove the ratchet and tap on the socket with a ball peen or brass hammer. Try again.
Old Jan 17, 2017 | 08:34 AM
Mopar5599's Avatar
Mopar5599
I never used loctite on my derby cover. Hand tightened the screws and the never came loose. I didn't want any issues with the screws sticking or stripping of they didn't want to break loose.
Old Jan 17, 2017 | 09:14 AM
Max Headflow
That's whats good about blue LT.. It acts as anti-sieze.. Sometimes don't even bother to use it. I agree about the TQ. I use a torx screw driver to RnR the cover.
Old Jan 17, 2017 | 03:03 PM
JMC22's Avatar
JMC22
No Loctite on the Derby screws - since the bike leans toward the Derby cover side, I had someone sit on the bike to keep it upright as I replaced mine - then step back and enjoy the new look
Old Jan 18, 2017 | 08:00 PM
NCBANDIT's Avatar
NCBANDIT
Originally Posted by NCBANDIT
I have a replacement derby cover on order and wanted to get any advice on unforeseen issue I may encounter when replacing. From what I have read I must keep the bike level to prevent fluid from spilling out. Since I don't have a bike lift I will improvise. Since the new cover doesn't accept the o-ring I have purchased a gasket. Do I need to use locktight on the bolts? Is a torque wrench a necessity?
I wanted to thank everyone for the useful tips. I ended up loosening the bolts, then put the kick stand on 2 2x4's. This brought it straight enough where no oil spilled out. See the pic.
Old Jan 19, 2017 | 07:28 PM
Ghost_13's Avatar
Ghost_13
We all had to start somewhere.., good job OP
Ghost
