Missing/hiccup
Old Aug 11, 2017 | 03:26 PM
Thekid338!'s Avatar
Thekid338!
5th Gear
Default Missing/hiccup
07 Ultra classic. Stock except exhaust. Recently have had hiccupping almost feels like missing while under load. Happens hot or cold, but not outside of 1st or 2nd gear. Replaced spark plugs, Engine Temp Sensor, Air filter and cleaned IAC valve in the intake. I also sprayed WD-40 on intake manifold areas to see if any RPM change and seems ok there.
I did have a O2 rich (p0152) code a couple weeks back that I cleared and have not seen back again. Any help before I break down and bring it in would be awesome.
Old Aug 12, 2017 | 08:42 PM
S.D.M.F's Avatar
S.D.M.F
Fuel pump / filter or fuel line in the tank.
Old Aug 12, 2017 | 09:18 PM
Thekid338!'s Avatar
Thekid338!
5th Gear
do I have to remove tank to check that stuff? I wud assume so right?
Old Aug 13, 2017 | 09:20 PM
S.D.M.F's Avatar
S.D.M.F
First thing i would do, is buy the correct service manual for your bike.
It will show you how to access them.
Old Aug 13, 2017 | 10:18 PM
Max Headflow's Avatar
Max Headflow
Second would be a fuel pressure gauge..
Thekid338!
Sep 18, 2017 08:43 AM
KiwiATC
Jul 4, 2016 07:02 AM
schuffyman
Sep 25, 2015 12:26 AM
jonzin67
Exhaust System Topics
Jun 21, 2010 11:32 PM
Bogey_52
EVO
Nov 8, 2008 12:53 PM
