Check Engine Codes
Old Sep 7, 2017 | 02:23 PM
Ksjmf's Avatar
Ksjmf
Stage II
Default Check Engine Codes
Thanks,
Mitch
Old Sep 7, 2017 | 09:46 PM
Oz Nightrain's Avatar
Oz Nightrain
Not sure on the 108 code but the other 2 are no combustion front and rear. This can sometimes be from the ion sensing side of the ignition. Check your leads are within spec and you should use oem plugs, don't even use the SE ones. If that all checks out maybe test the coils. Good luck.
Old Sep 8, 2017 | 06:27 AM
frannieannie's Avatar
frannieannie
I previously found this attachment of harley codes on another site. I hope i attached it correctly for your review, KSJMF
File Type: pdf
Old Sep 8, 2017 | 06:31 AM
frannieannie
Here's another document i had; don't know if it's different from the first i posted but there are codes on here too.
File Type: docx
mwriggs
Jul 24, 2012 07:56 AM
Smug
Mar 6, 2010 10:43 AM
dgretz
Sep 1, 2009 02:39 PM
johnsonabq
Aug 10, 2008 11:05 PM
docsg
Sep 10, 2007 10:45 AM
