Check Engine
Old Sep 3, 2009 | 08:38 PM
Smug's Avatar
Smug
Default Check Engine
Hey guys, when I start my bike the MIL light goes off after a couple seconds like it should, then it comes back on for 10 - 15 seconds and goes off again and all is good while riding. Any thoughts? 07' Train, big bore kit, 204 cams and PCIII Thank You...
Old Sep 3, 2009 | 09:13 PM
streeteagle's Avatar
streeteagle
I had same thing happen. When it goes off it is a historic code & means it has resolved itself & will go out after 50 start cycles. If it stays on it is a current code. To check the code, with ignition off & engine switch on, turn on ignition while holding in the odometer reset. Speedometer needle will sweep up & back down, & display will say: DIAG. Hold in odometer reset for at least 5 seconds & code will be displayed. Google Harley trouble codes & you will be able to find a list which tells you what your code means. To clear the code hold od. in for 5 seconds, turn ign off. My code was front cylinder no combustion, which was caused by a loose plug wire.
Old Sep 4, 2009 | 06:12 AM
Smug's Avatar
Smug
Thanks, Eagle. I followed your steps (perfect) but after the DIAG. display no codes came up???
Old Sep 4, 2009 | 06:20 PM
streeteagle
Sorry, I neglected to tell you after you see DIAG , push once to give you the section error is in, THEN hold in at least 5 seconds to get code. If there is no code it will say NONE.
Old Mar 6, 2010 | 10:39 AM
fuzz35's Avatar
fuzz35
what about this scenerio....my buddy's bike..02 duece..riding down the road, the speedometer will quit and the engine light will come on .. bike still runs, no other obvious symptons...anyone ?
Old Mar 6, 2010 | 10:43 AM
SBJJC's Avatar
SBJJC
Tell him to turn in his Honda and buy a Harley... sorry, i couldn't resist
SPARKY01
May 14, 2011 08:25 AM
jstoy215
Oct 13, 2009 03:46 PM
Agnes the dog
Jan 25, 2009 11:50 PM
central
Sep 29, 2008 06:50 PM
abjones
Nov 9, 2006 09:26 AM
