lighting
Old Oct 18, 2017 | 02:35 AM
Jeffcruz's Avatar
Jeffcruz
5th Gear
Default lighting
hello. i have Harley breakout and I'm wondering why my front right turn signal and running light not working bulb was replaced but still not working. I used a light tester to test for power it works both running and signal but when install the bulb not working already clean the contact. any advice on this issue will help. thank you jeff cruz
Old Oct 18, 2017 | 02:47 AM
K9F's Avatar
K9F
Welcome to the forum from the U.K.
Presumably when you used the tester you grounded it elsewhere? Bad ground/earth from the holder?
Old Oct 18, 2017 | 10:22 AM
Jeffcruz's Avatar
Jeffcruz
5th Gear
Runnig light and signal was'nt working befor i used the tester i put new bulb still no light. So i test the contacts with light tester it has power im confuse��
Old Oct 18, 2017 | 11:07 AM
K9F's Avatar
K9F
Test the bulbs or fit the known working one in from the front left.
Old Oct 19, 2017 | 06:49 AM
RANGER73's Avatar
RANGER73
Is it an LED bulb? Did it ever work? Swap it with the other one. Could be a bad bulb. **** happens
Old Oct 19, 2017 | 10:26 AM
bustert's Avatar
bustert
take k9's advice. probe contact with test light grounded to shell of the socket, if it does not work, like he said no ground path. bayonet bulb? have it inserted correctly?? h/l pins
gmorgens
Feb 8, 2016 05:36 PM
fatfatboy
Apr 12, 2015 01:22 AM
jb1023
Apr 24, 2011 11:27 AM
endngrdspecies
Electrical/Lighting/Alarm
Nov 28, 2008 04:33 AM
mnbagger
Apr 15, 2008 07:45 AM
