General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
You need a similar piston because of the shape of the combustion chamber. If you used a flat top for example, you'd have a serious drop in compression.
Thank you Ed , that's what I though. But I'm having a hard time finding them. I didn't know if someone else may know of a piston company that makes a replacement for them. Harley no longer has them or even make them, that's what I told by two different dealership . Thanks again for your help.
The standard bore was 22483-04 (you listed 22438-04). .005" over is 22484-04 and .010" over is 22485-04. I'm pretty sure with some searching you can find one of those - just start out .005 or .010" over. See if they are in stock here.
