Battery Problem, Please Help Me :(
Old Apr 19, 2018 | 09:41 AM
im's Avatar
im
Based on information provided it is reading like:
Bike is charging
The battery is able to accept a charge
Battery is UNABLE to maintain a charge.
Consider a battery load test.
Then a parasitic drain test using a digital meter between negative battery post and disconnected negative battery cable would be a final test.
An aftermarket alarm or some solenoid clicking could drain a battery and the parasitic drain test would help investigate that situation.
Old Apr 19, 2018 | 11:07 AM
Max Headflow's Avatar
Max Headflow
Bike is charging
https://www.youtube.com/watch?v=KF1gijj03_0
This is what you do after you verify that the battery is no going dead by itself due to excessive internal leakage. As shown in the video the first thing you need to verify is that the battery is good.
Old Apr 20, 2018 | 04:51 AM
jackietan's Avatar
jackietan
Originally Posted by bagga
a" genuine harley davidson battery" isn't necessary. the bike doesn't know what the label on the battery says. any brand battery that is the right size and amps will work in the bike. the last battery i bought doesn't say "harley davidson" on the side of it and it's going on 9 years old.
Which brand do you used that work well
Old Apr 20, 2018 | 06:57 PM
bagga's Avatar
bagga
AGM battery, i don't remember the brand name. i bought it at a farm store here.
jackietan
May 5, 2018 06:57 PM
jackietan
Electrical/Lighting/Alarm
Apr 18, 2018 12:25 PM
PROVIDER7
Dec 10, 2016 08:41 AM
bell927
Jul 9, 2015 09:39 PM
Jezcruzen
Sep 5, 2006 05:58 PM
