Engine/frame compatibility
Old Nov 4, 2018 | 07:27 PM
crazyape's Avatar
crazyape
1st Gear
Default Engine/frame compatibility
I own a 2004Softail Standard FI (FXSTSI). I was wondering if It would be possible to swap out my twin cam 88 and 5 speed for a newer 103 and 6 speed? What about the swing arm and wheel set up?
Old Nov 4, 2018 | 09:52 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
It's going to take a lot of engineering and modifying to accomplish. Not a direct bolt in swap.
Old Nov 5, 2018 | 12:14 PM
nevil's Avatar
nevil
Why not just build your 88? A lot less money and with more power you can change your final drive ratio so the 5 speed works better.
Old Nov 5, 2018 | 03:54 PM
grbrown's Avatar
grbrown
Thumbs up
And there are 6-speed conversion kits available.
Old Nov 6, 2018 | 10:46 PM
crazyape's Avatar
crazyape
1st Gear
Thanks for the responses. I have no interest in cutting up my frame so the 103 will be ruled out. I will be looking into the options for my 88.
Old Nov 7, 2018 | 04:16 AM
grbrown's Avatar
grbrown
Talking
We have HDF sponsors who can help you, including Hillside Cycles and Fuel Moto, both of them with various tuning packages. Also S&S offer their T111 replacement engine, as well as a 124" and, if they are still not quite enough, a 143"! Plenty of choice available, of proven upgrades.
Old Nov 8, 2018 | 10:28 AM
Max Headflow's Avatar
Max Headflow
I don't know about softails but suspect that the swap works if you use motor/tranny/primary. You can swap a 07 up bagger motor/tranny/primary into a 06-earlier bagger as long as you keep the motor/tranny/primary together.
Herv The Perv
Flathead
Nov 1, 2013 06:32 AM
HogglyWoggly
EVO
Nov 28, 2012 11:27 AM
HOG CHIEF
Aug 22, 2010 09:22 AM
jsbridgew
Jan 12, 2009 02:58 PM
roxx1
Oct 11, 2007 01:59 PM
