Looking for some info to upgrade my 00 EGlide TC 88 to 107 or 110.. a couple a weeks ago i saw a thread in here that recommeded some sites, but have not been able to find it again...any help would be appreciated.
+1
You'll need to split and bore the case for anything over a 95ci, so you might as well go the distance if you want that many cubes!
A 95 is a good runner too though!
+1
No.
He can go as big as 98" before splitting the case.
harley has a new screamin eagle 120 for just over five grand. to build yours into the 107 or 110 would likely cost that much. check their 2011 parts and accesories catalog. you could sell your motor to cover part of the cost of the 120 also.
The 120 might not fit, I think it will only fit the 06 and up mounts.
As your bike is carb I would go for an S&S 113 or 124 crate motor with a carb, it will be a bolt in job.
