Welding table?
Old Nov 25, 2018 | 09:44 AM
duoglider's Avatar
duoglider
Default Welding table?
I am getting into welding and rounding up things I need. My rig will be set up in my 500sf woorkshop, which has a double garage door. Black Friday this year was targeting for a Mig welder that I've had my eye on since last year so I saved some good money on the welder and personal supplies. I have a welding cart coming in soon but have been looking at welding tables.
I have a 40 yr old Black and Decker Workmate table, that folds up for easy storage, has metal legs, and a wooden top. So I'm wondering if I could just put a metal table top over the wooden top and use it as a welding table, as opposed to buying a welding table. Right now I don't need anything larger than the old Workmate, which is about 36x36".
I know I can build a table, but being a beginner that's not on my 'table' yet.
Open for ideas on options and hope to get some input from welders.
thanks
Old Nov 25, 2018 | 12:35 PM
hvacgaspiping's Avatar
hvacgaspiping
thanks
I wouldn`t use anything that had wood in it, or for that matter, anything that was even remotely combustible. You`d probably have to put metal at least 1/8" thick to have any degree of safety. By the time you spent the money on that, you would be nearly able to afford a welding table that was safe and sturdy enough to support a decent vise and the weight of items you would weld. Like it or not, you`ll have to spend some cash for a decent welding table. Here`s one that`s decent, has some nice features and is not too expensive: https://www.weldersupply.com/P/653/S...NomadWeldingTa
Old Nov 25, 2018 | 09:50 PM
Longridertx's Avatar
Longridertx
If you have the mig welder, 4 pieces of pipe for legs. some angle iron for cross braces, and a 36" x 36" piece of 1/4" plate would be a good cheap start for a welding table. It would be something easy to weld up and plenty good for a table to last a while.
Old Nov 25, 2018 | 10:02 PM
bad tappets's Avatar
bad tappets
I bought a Harbor Freight folding welding table. It’s better quality than I thought it would be. About $60, should work well to get you going.
Old Nov 25, 2018 | 10:23 PM
Hurricane 68's Avatar
Hurricane 68
Default Salvage yards
hit some scrap and salvage yards some times nice tables come in and sell for cheap it's 48" square just right size
One in background picked up cheap put casters on had for 25 years now 1/4"steel top it's all good
Old Nov 26, 2018 | 12:43 PM
hvacgaspiping
, `Would definitely be cheaper.......
Old Dec 5, 2018 | 11:55 AM
Eggman1's Avatar
Eggman1
I would definitely make that my first welding project. I would think that down in Texas there should be a few places with some steel plating that one could pick up for a decent price. Add some pipe for the legs and there ya go.
Old Dec 11, 2018 | 07:56 AM
gigihurt's Avatar
gigihurt
I built mine from 3/4 plate steel and angle iron and square tube. Also put it on steel casters to roll from one side of shop to the other.
Old Dec 12, 2018 | 05:01 PM
bigjames4xl's Avatar
bigjames4xl
Yep, build yourself one from scrap metal, metal recyclers usually have all kinds of things, sometimes even old metal tables that can easily be refurbished and put to use. I've made more useful things with scrap metal than new metal.
Old Dec 25, 2018 | 12:32 AM
Butter_C's Avatar
Butter_C
Stage III
The heavier the better if you’re going to fab. I’m a fabricator/repair welder on heavy equipment, the amount of beating a table takes is insane. My table at work is 3/4”, 5’x10’ with I beams underneath it. You can weld **** to it and make jigs, heat, beat, all that stuff. For home use, I’d still go with as thick as you can. Wood is fine but it’s bouncy. Plus, the thicker it is the sturdier it’ll be. Throw **** on it, stand on it. So ya my take is bigger is better when it comes to tables.
