Cable connections stuck in handlebar
Old Apr 13, 2019 | 04:47 AM
adiddik's Avatar
adiddik
Default Cable connections stuck in handlebar
Hi all
So was in the process of installing Lucky Daves 11" T bars
Whilst pulling through the throttle-by-wire cable, the plug connections got stuck.
I used some force to try and pull it through but as you can guess, the connections broke off and I only managed to pull the cable through
This has left me with two plugs stuck in the handlebar. I have greased it up greatly, and used some rods to try and move them but no success
About to get a snake cam so I don't have to work blind
Any suggestions on how to get the plugs back out?
Thanks!
Old Apr 13, 2019 | 05:52 AM
gdishman's Avatar
gdishman
Did you try compressed air and the rods? Keep digging them out.
Old Apr 13, 2019 | 08:04 AM
adiddik's Avatar
adiddik
Compressed air didn't work but some plumbing rods did the trick. That, mixed with the camera eye and a full morning,
Now to put the connectors back to the right cables
Cheers!
Old Apr 13, 2019 | 08:54 AM
MyFavRk's Avatar
MyFavRk
My advice , is to get rid of the connectors all together and solder them in place . Much easier to pull through .. Have done 3 sets of bars with no issues .
Old Apr 13, 2019 | 09:02 AM
touchdown's Avatar
touchdown
Just cut them in half they should come right out
evobigape
Apr 28, 2018 05:52 AM
twig
2014-2024 Touring Models
Mar 2, 2015 11:29 AM
Picit
Oct 24, 2013 07:30 AM
Tangle Eye
15
Jul 19, 2013 10:51 AM
SteelCityRider
May 27, 2011 06:24 AM
