General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I bought a used 2018 Road Glide. As far as I know the suspension is stock. Having a significant problem with scraping the 4.5" V&H pipes while turning. Current shocks are 11" and I'm wondering if going to 12" or even 13" will compromise handling. I'm 6'2" so seat height is not a concern. Will I need to do something with the front end at the same time? I know that the bike looks great at the current height, but I'm a function over form type of guy. If I swap out shocks, I will Probably upgrade to Ohlins or Axeo, I just don't want to commit that cash if I'm creating other issues. Also, does anyone know if the fork springs on that bike are shorter than a normal FL? Thanks.
11 inch shocks are not standard on any Roadglide.
RG Ultras come standard with 13 inch shocks so, you will be fine going to that length. Fact is, until the current trend of wanting a lowered look, most touring bikes had 13 shocks as standard.
13 inch socks will give you a better ride, better handling, and better performance particularly since you are not inseam challenged.
All that said, if someone put 11 inch shocks on it, they may have also put a 2 inch lowering kit on the forks. You might want to have that checked and go back to standard height.
Birdman has covered it. Fitting 13" shocks will improve things as far as ride comfort, cornering clearance and handling are concerned. it is common for owners to fit shorter shocks and leave the forks unchanged, however there are lowering kits available to do that. If you chose to fit Ohlins shocks I can also recommend their FKC fork cartridges, which should provide a major improvement all round, at a decent cost. Sponsor Howard at Motorcycle Metal is well worth contacting.
great input guys. Thanks. I compared distance from the cowbell to the front axle on my 2018 vs. the 2010 EG and they are both about 12"; so I don't think the front was altered. I've got some shopping to do.
On my 2018 Road Glide I pulled the 12" hand adjustable shocks and put 13" air shocks on it. It handles just as good. Unfortunately the ride still suxs. If I was closer to FLA I'd go see Howard at Motorcycle Metal. There are no shock guys in the midwest. Big surprise.
On my 2018 Road Glide I pulled the 12" hand adjustable and put 13" air shocks on it. It handles just as good. Unfortunately the ride still suxs. If I was closer to FLA I'd go see Howard at Motorcycle Metal.
You're in the same country as Howard! I'm in the UK and am a happy customer....
