Battery Keeps Dying
Old Nov 16, 2019 | 04:42 PM
mstrlucky74's Avatar
mstrlucky74
Default Battery Keeps Dying
So I've been keeping my bike outside and covered during summer. Getting cold here in NY so I will be bringing it inside next week. When I don't start my bike for 2-3 weeks the battery dies. I've got the battery load tested and it's good. If I jump the battery the bike starts right up. Any reason why it dies like this and should it be dying when not started for a few weeks? It's a 2017 with about 1200 miles. Thank you.
Old Nov 16, 2019 | 05:15 PM
MyFavRk's Avatar
MyFavRk
If your bike has a security system or something that would be drawing power from the battery , that would be enough time for it to drain it to the point where your starter becomes fussy . I suggest hooking up a battery tender if you plan on leaving the bike sit for more than a week .
Old Nov 16, 2019 | 05:41 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Put a DC volt/ohm/amp set to amps between one leg of the battery cable. Should me less then 150 mil/amps that alarm, speedometer, ECM and that other brain that does wireless stuff. When first connected, it will spike a little but then trim down .
These small batteries are hard to test without sensetive equipment. I bet it is battery. Year ago when my 3rd one was going, I nursed it along having it checked twice and both time said it was OK. A new one fixed my problem. Now when I get a few kickbacks or grunts, I just get a new battery.
Old Nov 16, 2019 | 06:05 PM
mstrlucky74
Originally Posted by MyFavRk
Does your bike have a security system ? That would be drawing power from the Bat .
No. But I did put new ape handle bars and put extension wiring kit on. Everything seems fine.
mstrlucky74
Thank you.
Old Nov 16, 2019 | 07:30 PM
Hey Man's Avatar
Hey Man
If you have a parasitic drain then I'd suspect a problem with the wire extensions. But before you tear it all apart get the battery load tested. Maybe you have a dead cell.
Old Nov 16, 2019 | 07:35 PM
mstrlucky74
battery battery was load tested and it's okay
Old Nov 16, 2019 | 08:44 PM
Max Headflow's Avatar
Max Headflow
Batteries develop internal leakage that will kill the battery over time. You need to pull the battery, charge it, measure voltage then let it sit for a couple days and measure the voltage again. If it's dropped more than a couple tenths, it's shot.
Old Nov 16, 2019 | 09:19 PM
TriGeezer's Avatar
TriGeezer
3 weeks is too long for the bike to s8tvwhout running, or being out on a battery tender. Bike batteries have much lower capacity that car batteries, yet have similar background drain.
Old Nov 16, 2019 | 09:21 PM
Max Headflow
Delete
