Horn Issues
Old Nov 1, 2005 | 08:40 PM
HDF Tech's Avatar
HDF Tech
Default Horn Issues
January 4, 2005
Horn Issues
Recently we have seen a high number of horn warranties.
Upon inspection of the returned horns there was no trouble found on many of them.
Here are some tips on diagnosing possible horn issues:
1. Horn volume is variable and will be different between two motorcycles. Perceived low
horn tone is not warrantable.
2. Water in the horn could also cause a low horn tone. It would be suggested to let the
horn dry and re-verify function.
3. Verify wire routings, connections, proper ground, and voltage.
4. Check for binding horn mounts.
5. Proper torque on the horn fastener is also critical and should be verified.
BadBobOk
Nov 20, 2010 11:12 PM
WARG
Jan 26, 2010 09:01 AM
jberg
Apr 25, 2009 06:06 PM
danielo
Apr 25, 2009 11:54 AM
