diagnostic module
Old Apr 2, 2020 | 05:19 PM
Kevin Cousins's Avatar
Kevin Cousins
Stage II
Default diagnostic module
I have a 2008 Electraglide Classic. I just had a bunch of work on my bike done this winter. Now, the check engine light is coming on. I'm trying to figure if there is a diagnostic tool that you can plug into the computer to see what's going on, without taking it into the shop.
Thank you for your help.
Old Apr 2, 2020 | 06:03 PM
dawg's Avatar
dawg
You can start by checking the codes through the speedometer and then look them up. There are historic codes that once cleared, will not be an issue. If a code comes back, then you need to determine what is causing it.
Old Apr 2, 2020 | 06:10 PM
Kevin Cousins
Stage II
Default How do you check the diagnostics in the speedometer?
how do you check the codes in the speedometer?
Old Apr 2, 2020 | 06:38 PM
MURPHCC1's Avatar
MURPHCC1
https://www.fuelmotousa.com/p-29661-...2FFLT%20MODELS
john duncombe
Engine Mechanical Topics
Apr 23, 2013 06:59 PM
tripacer1
Aug 31, 2012 08:32 AM
Alan7407
Jun 15, 2012 03:26 PM
Nathan918
Sep 4, 2009 10:45 AM
jimmers1817
May 4, 2009 07:16 PM
