General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
76 fxe tank questions..need advice pls..want to get away from the one piece sport Bob tank..I have a modern mounting kit on the way..I assume I would be able to use a shovelhead tank or a modern softail tank now?..witch route should I take?.. it looks like all you'd have to do is take off the l brackets for the sh tank...thanks. Needing to get some tanks ordered.. needing to know what I need for parts..
What? wm77......you come in here and ask a question right off. Don't we get a kiss or sum'ting 1st mate? Huh.
How do u like them apples?
It is optional my friend but you can click HERE and that will take you to our Welcome Area Only where you can introduce yourself as well as several of us would like to welcome you here.
That is also where you see the HDF rule. On the upper portion of the Welcome Area Only where the Stickys are. Like where to post what.
See below, this little chart thingy here is just for you mate.
This chart will help you post in the right forum.
lol...sorry about that, but ive been a member since 08..was on the mobile and was in a hurry to get some answers..was looking at a couple different deals, certain parts on the way and the start of my weekend to try to get things done and possibly runnin..just got my first harley back after 15-/+ years...just stocked to hear the ole girl run again...i did end up getting the soft tail tank..again in a hurry, i guess i need to slow down and make a plan of what im hoping this to look like..dont care for the (quick bob) tank and it needs a good cleaning inside , paint is out dated also..so...learning and figuring out what i will need to convert it over to (modern flat side tanks)..i got the fl dash and speedo with it(not sure if it works)..or i might get a lowrider dash and speedo to keep from moving the switch..idk....kind of hopin i dont have to cut the rear brackets off the frame to mount the tank kit thats on the way for the softail tank..any advice before i get to deep and sell off all my assets for parts?...thats what i do...lol thanks
