08 flhtcu
Old May 28, 2020 | 10:42 PM
dougsort's Avatar
dougsort
Stage I
Default 08 flhtcu
Just replaced the battery, bike sat for 8 mos added new fuel. Now it starts but does not stay running. Thoughts?
Old May 29, 2020 | 05:22 AM
BuzzCap7's Avatar
BuzzCap7
Hi dougsort, good to have u here. I moved ur post to what is likely a more appropriate area.
See this below my friend. And BTW, Rockport as in Maine? THAT is a GORGEOUS area.
Old May 29, 2020 | 07:33 AM
MyFavRk's Avatar
MyFavRk
If your bike sat for 8 months without any fuel stabilizer in it , you might still have some bad gas lingering in the lines to the fuel injectors . Throw in some sea foam to help clean out the system and get it running properly , about 1 ounce per gal . Check your throttle body and make sure the butterfly is clean and not blocked with carbon .
Make sure your battery cables are clean and tight , at both ends . Might want to test for voltage as well . Charge up the new battery first , get yourself a battery tender if you don't already have one . Ignition on battery should read 12+ v , idle at 2000 rpm should read 14+ v , but should not go above 15v
Check the bike for error codes , if any post back results .
Edrps
Sep 30, 2019 04:01 PM
djcustom1
Softail Pictures
Jan 14, 2010 07:30 PM
shekmark
Aug 4, 2008 08:54 PM
Ultra_Bob
Aug 23, 2007 07:54 PM
huffhuff
Jul 11, 2007 11:47 AM
