General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
check with the LED flashlight before ya dig in to taking it out.
I could be wrong, I doubt it, cause I've never been wrong in my life!!!
Been mistaken a few times, but never wrong!
Here's the update guys. I pulled the tank and pulled the hose. I replaced with the submersible fuel line. I did not see a hole in old line, but bike is starting perfect now and has great power on top end. Plus the bottom end stumble is gone.
well, spoke to soon. Started fine all day, now back to the extended cranking.
Just read another thread from a guy with same exact problem. He said they found out that the comp eliminator with the 551 cams was the problem. That is same setup I have. Something about it spinning engine to fast and messing with the spark output.
never say never, but, the signal is taken off the reluctor built into the flywheel so cranking speed is not relevant. you eliminated the cps so, use an inline spark tester to see if you have a consistent output. you can also use a noid to test injector signal. also, test cranking voltage drop on the battery. then there is intermittent connections, a sign that when you fiddled around with the machine, it ran fine for a day.
I did check spark with an inline tester. During cranking it would not spark, but when you release start button, it would so a spark. He said his did same thing. He said S&S told him it was something with the easy start cams and the compensator eliminator that confused the computer. Once he put a compensator back on,, it fired fine. Makes sense since i had no problems till I put on the solid sprocket.
Now I do think it had a hole in fuel line too, since my topend got more power since I changed line.
Trying to see if someone has a rotor laying around, so I can put compensator back in. Since it was the rotor cage that broke, not the compensator itself.
I've not messed with the 551 cam or it's automatic compression releases but do know for sure that the Delphi system needs to sense a slowing of the crank when coming up on compression on the rear cylinder or no spark will occur. A stock 08 really don't have much compression. Adding auto releases combined with the solid comp might be screwing up with the crank velocity sensing. Your best bet IMO is to put the old comp back in and see if the bike starts better. If it does, install an SE / late model comp You may want to check the condition of your battery and connections also. If battery voltage drops too much, the ECU may not put out spark / fuel. Spinning the motor faster might help with the sensing of the slowing. Check voltage while cranking, should be over 9.5 volts.
thanks, thats the plan. Battery is brand new and every connection on the bike has been gone through. Did not happen till solid sprocket installed, so I think it is causing the problem with the auto compression release on the EZ start cams.
I have not had the issue, I like my compression.. IIRC there was someone on the forums having an issue with the 570 cams in a 07-10 96 ci baggers without the comp change. 570s have bit later intake close than the 551s, so cranking pressure would be lower. Without enough cylinder pressure to slow the crank enough on the rear cylinder, the ECM does not know which cylinder is coming up on compression so it won't fire spark or fuel.
