2016 Electra glide police
Old Sep 11, 2020 | 05:21 PM
Brandon Carter's Avatar
Brandon Carter
Stage I
Default 2016 Electra glide police
I ordered and installed a radio bundle kit from Fathead Cycles. The kit comes with wiring harness, radio, antenna, speakers, and hand controls. After installing all the pieces of the bundle everything works except my horn. I have checked fuses, and the horn it self but it will not work when button is pressed. Has anyone else ordered these radio bundles and had the same problem. Thanks
Old Sep 11, 2020 | 06:09 PM
NODYNA's Avatar
NODYNA
If the installation involved replacing the left side switch pak either it's bad, one of the horn wiring pins is in the wrong position or not looked in place. To start check for a short/lose pin in the connector it will be shorter than the others on the pin side, on the female side check if all of the pin sockets look the same and give each wire a slight tug to verify they are all locked in place. I don't have a wiring diagram to tell you what color wires to check.
jakobstone
Jul 29, 2024 07:19 AM
Don R
EVO
Jun 11, 2020 03:07 PM
namuch
Oct 30, 2010 03:02 PM
94ultratour
Jun 29, 2010 10:22 AM
tucdog
Sep 20, 2007 08:24 AM
