General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hello.I own an 06 Fatboy with 22000 miles.Its an injected model.I live in the NE Georgia mountains,so I get to ride some awesome roads! I have had the bike for a little over a year and have an issue I could use some advice on. About 5 time in the past year the bike just shuts down. Today it did it at 70mph coming down a mountain. Steady throttle and then it dies, No warning, no check engine light...just a dead engine. Pull in the clutch and it restarts and heads on! This could get dangerous. In the past it usually would do it when I was coasting, then try to give it throttle. A couple times there was a small puff backfire when it quits. .I might go a month that it runs perfect..No rhyme or reason and I cant make it do it! any ideas? I have been told that possibly changing the TPS might solve it? Bike is a stock 88 with stock exhaust. Thanks for any feedback.
It might be the TPS, could also be loose/dirty battery and ground cables or a clogged fuel filter. Have you checked the plugs and plug wires?
You should also check for codes: Harley Trouble Codes
Wouldn't hurt to pull your run / kill switch and check that , spray a little electrical contact cleaner into it and work it back and forth .
Another thing that comes to mind , would be the ignition switch itself , check the connector as well as the connection at the ign switch . Try running the bike and wiggle those wires around and see if you can get it to cut out . Sometimes the contacts inside the switch will corrode and cause poor contact . not sure exactly what switch you have , but some can be taken apart and cleaned .
Thanks for the replies. I have checked the battery, plugs, and wires and all is good there.The fuel filter has not been checked yet .I will pull the switch and clean it.That is a good possibility.The bike has no codes in the memory and never throws one when this shutdown occurs. Scared the **** outta me when it did that at 70 mph , and on throttle! Glad I wasnt on a Interstate.
