General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Does anyone carry a portable jump starter with them? If so what u got? My bike starts like crap in the cold. It was in the twenties and I had a hard time firing up.I don’t want to get stranded at work if it sits out all day.
I carry one in the farm and one in the bike.ibrecentky bought this one for the car, and had to use it almost immediately. Started our 3.7 liter v6, without even a small breadth. And still had 90% capacity left.
TACKLIFE T8-Newer Model 800A Peak 18000mAh Car Jump Starter with LCD Display (up to 7.0L Gas, 5.5L Diesel Engine), 12V Auto Battery Booster with Smart Jumper Cable, Quick Charger(Yellow) by AutleadDirect Learn more:
if your bike starts like crap in the cold, you should check out your charging system, and battery health. And make sure you are starting it in neutral With the clutch pulled in, and aren’t running too heavy of motor oil.
Oh yeah, I also have this one. I misplaced it in the garage, and just recently found it. So, I haven’t charged it in over 2 years, and it’s still at 3/4 capacity. Abd it has started sever bikes, cars, and a pickup truck.
I have a similar cable for Reaper, and an adapter that has an SAE connector on the end, so I can use it for my Battery Tender, too. Just unplug the adapter, and plug in the Weego, when I need to.
