General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hello....so I ordered the Woods TW6H cams for my 98" build.
I know these cams are a .590 lift , I also read that woods cams are hard on the valve train.
would Roller Rockers help with this and which ones would you recommend.
Are there such things as a good roller rockers at a reasonable price???? Although being in Canada there's no such thing as reasonable pricing when it comes to our rides.
My guess is that the only thing roller rockers will add to your build is noise.
Lots of pro builders here on the forums, hopefully some will chime in.
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
With .590 lift you will need roller rockers, and be ready to accept some noise. Roller rockers are inherently more noisy, but Wood cams tend to be noise anyway.
