General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I've seen some on here disable their ABS, sure that wasn't done on yours ? Hey, you should pop into the new members welcome area and introduce yourself.
I think it needs the Digital Technician to disable the ABS light on non-ABS motorcycles. Not sure what all could cause it to to come on. How long have you had the RK? Have you messed with the Speedometer, etc?
I would check the connector where the abs unit would go to make sure no dirt or water got into it.
The second thing I would do is unplug and plug back in the speedo assembly to ensure there is a solid connection there.
