Help
Old May 15, 2021 | 07:40 AM
Joshua Shug Trehan's Avatar
Joshua Shug Trehan
Stage III
Default Help
Just wired my apehangers on got turn signals on but my fuse keep blowing on my turn signals and tail dont know if I have a pinched wire somewhere to cause that or what can some please help I'm lost
Old May 15, 2021 | 11:00 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You should only post your question in one section of the forum, and there is no need to start a new thread when you give new information.
If the fuse keeps blowing, it means you have a circuit that is shorted to ground.
Most likely you crushed a wire in one or both of the control switch housings.
What fuse is blowing?
Does it blow as soon as you turn on the ignition switch?
Old May 20, 2021 | 11:45 AM
DanHappy's Avatar
DanHappy
Take all metal groups apart where the wires cross and look for pinched wires. If all good, check to make sure the wiring is correct. Could have some pins mixed up. How did you do the wiring? Extension or more wire and solder?
Lots of people here to help. We all went thru this one time or two...
TPost
EVO
Nov 21, 2016 11:53 AM
SouthernGent
Dec 3, 2012 07:36 PM
dpriest
Dec 21, 2008 08:53 PM
lovethemhogs
Sep 10, 2008 08:30 PM
bobbsterkid7
Aug 28, 2007 01:12 PM
