fuel tank trim
Old Aug 24, 2021 | 09:38 AM
btfatboy2018's Avatar
btfatboy2018
6th Gear
Default fuel tank trim
i have a 2018 fat boy and am trying to remove the trim piece from the gas tank any suggestions would be helpful i tried to remove the 4 torx bolts but that did not work
Old Aug 26, 2021 | 12:16 PM
pgreer's Avatar
pgreer
I believe there is a bolt or two under the seat that needs to be unbolted to remove the console. So I'd remove the seat and check for fasteners at the back of the tank for the console.
Paul
Old Aug 26, 2021 | 12:55 PM
btfatboy2018
6th Gear
there is a single bolt under the front of the seat but the trim piece has 2 bolts attaching it to the spedo console they appear to have bolts with slip nuts that i can not reach without the console lifting up that is my problem do you know how to get the console off? i tried the one bolt on the console itself but it would not lift
thanks for your help
Old Aug 26, 2021 | 02:02 PM
eighteight's Avatar
eighteight
Old Aug 26, 2021 | 02:08 PM
btfatboy2018
6th Gear
thank you brother!!
Old Aug 26, 2021 | 02:18 PM
btfatboy2018
6th Gear
by the way where did you get that from?
Old Aug 27, 2021 | 03:35 AM
eighteight's Avatar
eighteight
Ronnie`s Parts Finder
blue bronco
Feb 2, 2013 02:53 AM
sioux565
Jul 17, 2012 12:51 PM
roadglidedude
Jul 15, 2009 07:10 AM
tatkin
Dec 7, 2006 09:43 PM
bensonjv
Jan 1, 2006 02:50 PM
