Turn signal mirrors problem
Old Sep 23, 2021 | 05:48 AM
CoffeeCritter's Avatar
CoffeeCritter
6th Gear
Default Turn signal mirrors problem
I recently installed turn signal mirrors on my 2001 Sportster 1200 Custom. They worked fine at first but then they started getting loose and I couldn't keep them where I wanted them. Now the left turn signal is not working. I'm sure that is just a loose wire.
My question is how do I get the mirror off so that I can fix the wiring and maybe also the loose ball joint so that they will stay where I put them.
One video said to run a plastic card around the edge of the mirror. I tried that and it didn't sčem to help at all.
Will someone please tell me how to do this?
Thank you!
Old Sep 24, 2021 | 06:35 AM
bustert's Avatar
bustert
is there two screws next to the ball? if so tighten those till the mirrors stay positioned. mine loosen also with high rpm vibs. as far as removing the mirror, it is glued in, supposed to be a one way ticket. maybe a little applied heat may soften it up, or bring it to an automotive glass shop.
Old Sep 24, 2021 | 06:46 AM
Iceman24's Avatar
Iceman24
In this case...pictures would be helpful.
Old Sep 24, 2021 | 06:51 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Without any information it is a stretch for anyone to help you.
What are the mirrors you have?
Old Sep 24, 2021 | 11:44 AM
nevil's Avatar
nevil
Have you contacted the vendor? If it's their product they might have a fix.
Old Sep 27, 2021 | 06:09 AM
CoffeeCritter
6th Gear
I have decided to just say to heck with the mirrors with the turn signals.
I'm just gonna go with plain mirrors with separate turn signals.
Old Sep 27, 2021 | 06:20 AM
CoffeeCritter
6th Gear
So I probably should get mirrors with those two screws next to the ball, huh? That way I could tighten them up as I need to, right? Plus I was thinking that if I got some round mirrors then I should be able to see in 'em even if they turned.
jayzee75
Feb 20, 2024 01:51 PM
RF_user21321
Dyna Parts
Apr 22, 2013 12:38 AM
micahpop
Oct 11, 2012 01:32 PM
dromano33
Jun 6, 2010 11:12 PM
Davii
Feb 1, 2009 03:28 AM
