heated grip woes
Old Oct 7, 2021 | 03:43 PM
Zappaflsb2019's Avatar
Zappaflsb2019
Stage III
Default heated grip woes
two weeks after the warranty expired on my very $$$$$ Kahuna Heated grips they stopped working (of course) lots of posts about these things failing......does anyone know if there is an inline fuse for the grips on a 2019 Softail? Wanted to start at that source first before checking the entire wiring. Dealer advises there are no replacement parts and that only other option would be to replace them at $$$ for new grips and $$$ for labor.
I live in the frozen north so sort of anxious to get these things re-working....maybe should have stuck with my 30 year old heated plug in gloves
Thanks folks
Old Oct 8, 2021 | 12:46 PM
NODYNA's Avatar
NODYNA
Many of the parts are available. Go H-D.com, search on heated grips, find yours, go to details. There you'll find the installation instructions and individual part numbers
Yes it should be feed by a fused circuit most likely through the H-D auxiliary power cable. The instructions will provide the power source/fuse information and connection locations that you can check for tightness and power.
Old Oct 8, 2021 | 01:18 PM
Zappaflsb2019
Stage III
thanks kindly......will look........dealer advises other wise but will check your suggestion for now and argue with them later
Gunny357
General Topics/Tech Tips
20
Sep 29, 2022 12:50 PM
Zappaflsb2019
Welcome Area Only
18
Oct 9, 2021 05:45 AM
11b50
Electrical/Lighting/Alarm
Apr 12, 2014 09:38 AM
tperro
Apr 19, 2011 12:56 AM
Silvertrain1025
Apr 3, 2011 06:16 AM
