Stators
Old Oct 10, 2021 | 04:56 PM
Naruto666's Avatar
Naruto666
Other than finding, following, and checking every wire, is there a test that can be done that might determine if a wire is pinched?
Old Oct 10, 2021 | 05:07 PM
WP50's Avatar
WP50
Unless it's pinched at the time of testing NO
There are usually obvious places for wiring troubles to start at before ripping a harness apart.
First the that came to my mind was a bad ground circuit for the voltage regulator Circuit would include all wiring and connections in that circuit.
WP
Old Oct 11, 2021 | 08:16 AM
bustert's Avatar
bustert
first off, the hd regulator (and stator) was designed marginal at best to just do the job to save $$$. the regulator grounds to the frame by attachment fasteners but some add another jumper ground. if you lose the ground, the regulator just quits, needs nothing from the outside as it internally senses system voltage. sometimes a bad battery will cause the regulator to go wide open.
in open air, the stator will actually stay cooler than if it is in an oil bath, but if you are running a dry primary with cover, that will change. the varnish on the magnet wire will take way more heat than the engine can produce via the cases. hard to say without seeing the stator.
sounds like a good aftermarket 3ph system would do better.
put an inline amp meter to see what the actual amperage is.
Old Oct 26, 2021 | 03:09 PM
hog95023's Avatar
hog95023
got a question about the stator removal. is there a puller needed to remove it or does it slide off and on easy after the compensator is removed. just took the comp off of my dads bike and put back on but was dumb and didnt check. since running an amp he wants to change it out before we head out in spring. want to have the tools needed before taking it apart again.
Old Oct 27, 2021 | 02:31 PM
Trucky911's Avatar
Trucky911
I know thats what an OEM bike takes thanks. How much fluid does an open air primary take? Gonna tell them to run 28oz as well?
I'm confused. How does an open air primary hold fluid?...
Trucky911
Old Oct 27, 2021 | 05:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Looking around some, it seems the biggest reasons why stators burn out are heat and over taxing the system.
The charging system can only put out so much power, and it runs at full capacity all the time...
The primitive voltage regulator system just dumps the excess power to ground to maintain proper system voltage.
Old Nov 13, 2021 | 08:18 PM
pgreer's Avatar
pgreer
There are a few things that need clarification. Perhaps I missed it, but what bike are you working on? Touring, Softail, Dyna etc? You mention adding 14 oz of oil to the primary, and then mention open primary. No oil goes in an open primary, so I'm not sure how that goes with this discussion. You might want to describe what you have and include a few pictures as well.
I think your builder is mistaken or there is a misunderstanding on the fluid amount for a closed primary. If the inner and outer primaries are stock the OEM fluid amount recommendation should be followed, less up to a few ounces. The type of oil may be dictated by the clutch material, but the amount the factory recommends is to allow the oil to do it's job. The oil helps carry the heat away from the stator, keeping temperature at a safe operating temp. I believe that much less oil will contribute to a failed stator, over time. And I believe it would likely to contribute premature wear on the compensator and inner primary bearing too as the same oil lubricates those parts.
Paul
rsking45
2014-2024 Touring Models
Aug 1, 2021 09:53 PM
98hotrodfatboy
14
Jul 14, 2021 01:38 AM
Whiskyjock
Feb 11, 2018 10:23 AM
big- mike
May 3, 2017 04:35 AM
richardn090383
Shovelhead
Jul 20, 2013 08:13 AM
