Dented fender
Old Oct 17, 2021 | 08:40 PM
plumb1bob's Avatar
plumb1bob
Default Dented fender
Well it happened. Trike parked in the garage. Moved it back and forth to get the pressure washer out. Somehow I either dropped something or something fell off a shelf on the front fender. Dented it right on top. Has anyone been able to get dent wizard or some other dent repair company to remove dents on a Harley fender. I have to call the dealership tomorrow to see if they have someone to recommend. Has anybody ever seen the dent removed. Triglide is Dark Magic paint. Can’t imagine what anew painted fender will cost.
Old Oct 18, 2021 | 06:24 AM
bustert's Avatar
bustert
well, my truck has been through two hail storms and it is amazing what they can do.
Old Oct 18, 2021 | 06:30 AM
Iceman24's Avatar
Iceman24
PDR shops can work magic...fixed both of my kid's cars after local hail storm (100's of dings) - definitely cheaper route - hope you find a place to fix your fender. Keep us posted...
Old Oct 18, 2021 | 06:55 PM
Cooch366's Avatar
Cooch366
I dropped a piece of wood and put a quarter size dent on my 2017 Limited. Went to Dent Wizard, 15 minutes later fender was good as new. Amazing and totally worked for me.
Good luck.
Old Oct 19, 2021 | 07:49 PM
plumb1bob's Avatar
plumb1bob
What did they charge you. If you don’t mind me asking
Old Oct 20, 2021 | 05:43 AM
Cooch366's Avatar
Cooch366
Default Cost
cost
if I remember correctly, $125.00
Old Oct 20, 2021 | 06:38 AM
plumb1bob's Avatar
plumb1bob
Thanks
Old Oct 20, 2021 | 08:02 AM
bustert's Avatar
bustert
shop around, prices vary widely.
if there is not a crease in the metal, you can use an english roller trick with a formica roller. they make diff sizes but it is a hand held roller with a rubber wheel used to make sure the formica is pressed firmly on the substrate. you need a soft cushion as a backer, a bag of fine sand would probably work.
Old Oct 20, 2021 | 08:50 AM
Kenny94945's Avatar
Kenny94945
+1 for professional dent removal service.
(I have seen miracles from these services)
I expect $75-$150 cost range - your location, local rate, etc.
Let them advise fender removal could be an option ease the repair.
Good luck, let us know the results.
Old Oct 20, 2021 | 09:03 AM
Uncle Larry's Avatar
Uncle Larry
PDR are remarkable ... I had a nickle size ding in the hood of my Silverado ... $75.00 later no more nickle :>)
CRGLIDER13
Touring Parts
Jan 14, 2016 10:55 PM
nkauf21
Oct 4, 2014 06:07 AM
teedubya
Jun 24, 2014 12:23 PM
Beach Bum
Pacific
Aug 25, 2008 11:43 AM
amike
Oct 3, 2007 11:34 AM
