Compression testing how to.
Old Nov 15, 2021 | 03:43 PM
Boxerguy8888's Avatar
Boxerguy8888
Default Compression testing how to.
I gotta be doing something wrong here because there's gotta be posts about how to do it here but my keyword search pulls nothing. So if anyone can answer my questions or point me to a thread that will I'd appreciate it greatly.
Novice home mechanic and I recently upgraded my cams on 2008 fatbob and even thought its running good, instructions say to perform a compression test. I've found a dozen different places with 100 different ways that all contradict eachother. Mainly with the electrical aspect. My bike is fuel injected, I installed woods 222 cams.
Do I unscrew plugs and leave them in the wires but lay them on the body/frame to ground them? Or do I just remove the plugs and let wires hang? Or do I just remove plugs and pull the fuse to the ignition?
also I'm assuming I want to pull fuse to the fuel pump?
Thanks in advance.
Old Nov 16, 2021 | 06:09 AM
pgreer's Avatar
pgreer
I just remove the plugs and let the wires hang out of the way.
Be sure you have a fully charged battery that will spin the engine fast and long enough to complete the test. You also need to prop the throttle wide open while doing the test so the cylinders can fill with air without the restriction. Crank the engine with the throttle fully open for about 5-6 seconds or until the pressure gauge stops increasing.
Some people suggest unplugging the fuel pump so no fuel is injected into the cylinders. I don't, but can see why some do. The cam you have added will likely lower the cranking compression a little because of valve timing differences from the stock cams. But that cam closes the intake valve early (34 deg) so you should still have good pressure.
Paul
Old Nov 16, 2021 | 04:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Now would be a good time to also do a leakdown test, just another way of establishing a baseline.
And a good excuse to buy another tool.
Old Dec 13, 2021 | 12:30 PM
carlmartine's Avatar
carlmartine
Can I jump in here and ask what the procedure is for a bike that has manual compression releases? Thx
78FXEBlue
Engine Mechanical Topics
23
Jul 3, 2021 09:16 PM
1 2 many
May 13, 2021 02:32 AM
JarJar
Apr 12, 2021 05:23 AM
Calendap
Nov 23, 2020 10:39 PM
TheBurninator
Oct 22, 2011 11:39 PM
