Socket / wrench size
Old Dec 23, 2021 | 05:18 PM
Chunky Monkey's Avatar
Chunky Monkey
Default Socket / wrench size
OK bone head question, but where in the service manual does it say what size socket to use on a given bolt. I can find the Torque spec but it does not say what size bolt or nut it is.
Thanks!
Old Dec 23, 2021 | 05:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Nowhere.
Not in a Harley Manual.
Not in a Honda manual.
Not in a Pratt & Whitney manual.
Doesn`t matter why, there are probably dozens of legitimate reasons.
Keep in mind, when you are looking at a Torque Table for fasteners; the fastener size is the diameter of the fastener, not the size of the wrench used.
Old Dec 23, 2021 | 05:38 PM
Chunky Monkey
Dang I thought I remember seeing it in there on my 14 when I did my front forks??
Old Dec 23, 2021 | 05:49 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Even the real oddball sizes aren`t called out, such as the size wrench for the 5 speed clutch hub retaining nut (1990 and later).
It`s a 1-3/16'", talk about an oddball socket to have in your toolbox...
Old Dec 23, 2021 | 05:51 PM
QC's Avatar
QC
What bolt or fastener are you trying to move? Maybe someone in here has done it before and can give the size.
Old Dec 23, 2021 | 05:55 PM
TriGeezer's Avatar
TriGeezer
I think the only one I’ve seen called out is the caliper bolts, Mostblikely because they are metric.
Old Dec 23, 2021 | 06:44 PM
Chunky Monkey
yeah I am taking off the two caliper bolts, I am guessing 12 pt and 10MM?
Old Dec 23, 2021 | 07:37 PM
Chunky Monkey
you know what is funny, I know with the manual for the 14 it did say the socket/wrench size in a table at the beginning of each area. if you were doing the front calipers you look at the beginning of the break section and it would list each bolt the head size, metric or SAE. Wish I had my old manual to confirm.
Old Dec 23, 2021 | 07:45 PM
QC's Avatar
QC
Yes, 10 MM 12 point. And if it has pad pins, those are 1/4" 12 point.
Old Dec 23, 2021 | 09:24 PM
Ron750's Avatar
Ron750
I have always wondered why they don’t tell you what size wrench you need. It would be easy for them, and save the user time. Especially when you don’t know if it’s SAE or metric.
