Timing Off Perhaps?
Old Aug 12, 2007 | 06:50 PM
KustimKool's Avatar
KustimKool
Default Timing Off Perhaps?
I was going to put this in the IGNITION section, but I figured that would indicate that I knew what the problem was when in fact, I do not. While I speculate that it is a timing related issue, I'm not certain. For that reason, I thought it would be acceptable to post this question here. Here we go :
I have a 1993 HD Sportster 1200. I have a backfire issue. When the bike is just idling, every once in a while there is a slight muffled "POOF" from the exhaust (not your standard Harley rumble noise - its a distinct backfire sound). When I am riding, while it is hard to hear with wind noise and what not, I don't hear any loud backfiring (when running at a constant speed), however, if the RPMS are up and I am throttling down (for example, immediately after a down shift) the engine will make a sharp "POP" through the exhaust (sometimes it will make 3 or 4, depending on the RPMs - the higher the RPMs, the more backfires). I also noticed, that in my garage in the dark and sitting at a stand still, if I give the throttle a good burst and let off I will achieve the same crisp "POP" and I can see a flame shoot out the exhaust. This flame is visible on both cylinders. I feel it relevant to mention that engine temperature doesn't seem to make a difference. I get the same response with a cold engine as I do with a hot one. I just got this bike a week ago and it has done it ever since I first test drove it. I would like to dig into this problem myself (I'm no dummy with mechanics but this is my first HD).
Suggestions? Advice? How To's?It's all good...Please help. Thanks!
- Dan
P.S. Do you need anymore information? Just let me know! Cheers!!
CAFXLR
Sep 6, 2014 07:59 PM
redbeard135
Jul 29, 2013 05:49 AM
Maple Leaf Hog
Exhaust System Topics
May 22, 2010 05:38 PM
rdb883
Aug 11, 2009 01:58 PM
DeepCobalt
Jul 24, 2007 11:10 PM
