5 year old wet sump
Old Mar 30, 2022 | 04:35 PM
bustert's Avatar
bustert
Default 5 year old wet sump
just got a 2001 twin cam that was set up the last 5 years and now there is 4 quarts of oil in the sump. BT are not my bag, last one was a 1974 fxe with manual foot.
there is a hex head plug under the cam case but i do not want to pull it so i guess the cover must come off.
short of turning it upside down what do you suggest?? (figure of speech)
it will run but with that much oil, really do not want the bump start method either.
getting toooo old for this!
Old Mar 30, 2022 | 04:57 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Remove the plugs and with a good battery, crank it over to get the oil back up in the oil bag. Once most of it is there, put the plugs back in and start it up, then change the oil.
Or you could pull the crank sensor and drain some out from there. Best is to crank over like above though, less mess.
Old Mar 31, 2022 | 09:56 AM
bustert's Avatar
bustert
thanks mr. cool
i will try the crank sensor port. i can set up a vacuum line to pull most of it out. beats removing the plug or oil pump.
Frazer900
Mar 31, 2020 09:26 AM
Lucky Luke
EVO
80
Dec 2, 2015 01:43 PM
Mikeduke108
Jun 28, 2014 04:08 PM
619er
Oil Archive (no new posts)
Nov 15, 2013 01:06 PM
NYCFXDC13
Jun 1, 2013 03:38 PM
